CV carb acceleration pump?
Old 10-13-2011 | 06:23 AM
kino44's Avatar
kino44
Default CV carb acceleration pump?
May be a stupid question just want to make sure Im putting the black round rubber acceleration pump Diaphragm in correctly? I would assume that the side with the ridge fits in on the ridge on the carb?? my bike used to have the original CV carb with no pump and ran great just seems not to run as good with the pump takes longer to warm up.Has anyone ever removed the pump lever and spring and ditch the pump? or is this not advisable? just curious Ive heard of people who have.
Old 10-13-2011 | 07:10 AM
RK05's Avatar
RK05
The diaphragm should have a 'lip" on it for it fit on one side of the carb (has a groove) but not sure side.
Can't answer your other question.
Old 10-13-2011 | 08:33 AM
kino44's Avatar
kino44
Default Diaphragm
So the lip would go in the grove side I would guess?
Old 10-13-2011 | 08:55 AM
JohnnyC's Avatar
JohnnyC
Not an option...
If you didn't have an accelerator pump the bike would be difficult to start cold, maybe even impossible.
You would stall / stumble on take off when the pump must give the bike an extra squirt of gas to get it to rev up and run faster.
Also you would have a big stumble when you want to pass, or speed up to enter an expressway.
Old 10-13-2011 | 11:44 AM
kino44's Avatar
kino44
Default acceleration pump
Originally Posted by JohnnyC
Not an option...
My old carb dident have one and ran fine so I belive the bike would start because the pumps not engaged until you pull the throttle back ill have to test it
Old 10-13-2011 | 01:39 PM
Gpsjr10's Avatar
Gpsjr10
A lot of older metric bikes don't have accelerator pumps and they run just fine.
Old 10-14-2011 | 07:08 AM
kino44's Avatar
kino44
Yep bike runs fine now just like it did with the other carb I have tried every setting with the new carb with acceleration pump it just doesent like the extra gas being shot in just dident run well.Its fine now with pump disabled I noticed the coiler spring is stretched as well its no good I called harley and they dont make it anymore but thats ok dont need the pump anyway
Old 10-14-2011 | 07:38 AM
JohnnyC's Avatar
JohnnyC
Glad it's working for you.
It just seems odd to me to not have the advantage of accelerator pump on a carbed motor vehicle. If a non accelerator pump carb works right for you then ... Ride On!
m1crazy
09-14-2022 06:18 AM
br549A1
EVO
04-08-2015 10:37 AM
CatHerder
Exhaust System Topics
06-18-2010 01:54 PM
kelton3
10-05-2009 06:41 PM
vailtl
07-11-2006 02:31 PM
