Iron plate mount
Iron plate mount
So I ordered a axle plate mount, did not realize it but the stock side plate is part ot the fender... Kinda, so if I remove it there will be a gap between the fender and the fender strut when looking at it from the side. Anyone removed the stock plate mount? Does it look ok?
[QUOTE=Aus Iron 883;8915052]I did the opposite, took the stock Aussie version off and out the factory u.s sidemount version on. the aussie (or export model) left plate is waht you need[/QUOTE
Haven't seen one, thinking I will get another reflector from the right side and see if I can make that work as a filler panel on the left. I will cut the reflectors off of course, trying to keep the stock plate mount in one piece so it can be sold
zimm
02-04-2013 09:06 AM
bosken
07-07-2008 09:40 AM
