Sportster Suspension
A few riders here aren't guys, but petite gals, which is a good reason for them to lower their rides. I've actually raised my SuperLow, to try to improve ride quality, which is seriously lacking with the stock set-up.
OK, lets get some opinions on how to proceed.
I am a big guy, 265lbs. so what I was going to do:
Change the rear shocks out with progressive heavy duty shocks:
http://cgi.ebay.com/ebaymotors/PROGR...ht_1263wt_1165
Change the front fork oil out using heavy weight 20 weight oil.
And possibly add progressive fork springs also:
My set up is Progressive springs, and BelRay 10W oil, 5.7 inches down from the top of the tube. This is what works for me.
I have Hagon shocks and RaceTech springs up front with Emulators on my SuperLow. Stock Harley fork springs are soft and sag too much, so your replacements need to hold you up better. Companies like Hagon take a set of dampers off the shelf and fit springs to suit each customer. That means YOU, not John Doe!
My indy really helped me wade through this same issue on my '02 sporty. He recommended the Works Performance brand because of the total build to specs deal. I really could not afford that set. The next recommendation was a set of Progressive 440 in heavy duty version for the rear. They look very similar to the first pic posted in this thread. We also switched out the front springs to hd progressive springs.
I don't care what you get brand wise, just sharing some info from another big guy (235) who rides two up a bunch with all the lil woman's stuff...which makes quite a load. For the two of us, I set the rears shocks to about half way and for just myself I back them off completely. The roads we have around here are horrible, we no longer bottom out on the potholes I fail to miss, the railroad crossings, and the curbs going into gas stations. I love how easy these shocks are to adjust with no tools required.
I am no technical wiz, have no brand loyalty, or care about the brand names. What impressed the heck out of me is how the suspension changes dramatically improved my ride quality. Good luck with your decisions.
