What the heck has happened (and how do I fix it)
my question would be... by no means being a smart mouth.. if this is only mode of transport, and it's a "leak" is it a panic fix? I'm really detailed and on any sort of issue with my bike. Usually get the smile and nod from my mechanic and the pat on the arm..."She'll live"
Leaks get fixed, but no panic. Just wondering for obijohns peace of mind...
I had a vstar that would do the same thing. It was the v star 650, I would blast that bastard on the freeway, wide open throttle and it would do about 80 mph sounded like it was going to hit the rev limiter. When I got to work I noticed that the cylinders were leaking oil just like what is shown in your pictures. If I rode it like a normal human being, it would not leak...maybe you just need to lay off the throttle a little bit?
Yeah, first things first: Identify and isolate the leak.
Clean that entire area really well, check it with a flashlight after EVERY ride and see where its coming from.
Once you know for sure where its coming from, you can pick a course of action.
If its only ever a drop of seepage at a time...hell, guys have ridden for years and years in that state.
Well, For ****s Sakes!
You guys don't have to be such ******** about it just because I'm a little ignorant about the "proper" way to fix it! I really didn't know and I was just trying to help with my earlier suggestion. Good thing that I really don't give a **** what you guys say :P
No, it's not at the panic leak point as of right now. He can ride it and keep an eye on the oil level/leaking amount. I'd suggest that he buy a service manual and a gasket kit so it can be fixed in the next couple weeks/months. This job is only a little harder than doing the rocker box gaskets since he'll have to strip it down to the base gasket.
Just keep an eye out on it, checking the level from time to time, and get it located and fixed as soon as convenient for you. Winter is coming up on us quick, perfect time to get 'er done. Try to locate the problem a.s.a.p. though, that way you will not have to ride in poor weather if you don't want to.
Thanks for all the comments guys. I'm a little more calmed down now I think.
I really don't push it very hard, rarely ever go above 3,500 rpms and never above 70mph on the highway. A week or two ago a cold front came through on my ride home. First time it had rained in forever here, and everyone forgot how to drive on wet roads. I was stuck in bumper-to-bumper traffic for about an hour and a half, then suddenly this very cold rain just pours down. I don't know if the sudden change in temp with that cold water hitting the engine after having been idling for so long might have loosened up something around the gasket or what. But I'm being optimistic about it just being the gasket.
Thanks again, I'll keep an eye on it and following the suggestions about isolating what's going on.
Same here. Takes less than a minute, and if you do happen to suddenly lose oil it is easier to detect when it happened, making it potentially easier to isolate what had happened.
