Tools, Torx, Torx+???
I am not a mechanically inclined person, did wrench on big mowers when I did lawn care back in the day. I can turn a wrench, just not a ton of faith in myself. I do have the manual and want to start doing some of my own stuff.
Can anyone tell me what tools I need? I have the basics, sockets, wrenches and the norm, what about the torx, or torx+ bits?
Any insight or links would be appreciated.
Torx bolts are awful .... I replaced all of them in my Sporty with either Allen / Hex heads... shock absorbers attached to the frame with Torx bolts ?... whahh ? u kiddin' me?...
Warrick.. as stated before... good quality Torx bit set is a good idea... same goes with Allen bits... try to get the most complete set you can find... sure.. they cost more... but it is going to save u time and money in the long run... a medium sized torque wrench is important!.. specially if you are going to work on the cases (primary, cams. etc)... I bought a couple from Harbor Freight and the are ok (when you work with the torque wrench... make sure you don't confuse INCH- Lb with FOOT-Lb )... and make sure you follow the procedures in the service manual !!!!..
Excellent, thanks for the advice...
$40 for a 7 piece Torx is too much... even Ace hardware has a more complete set that costs less...
please look into these options:
http://www.homedepot.com/webapp/wcs/...&Ntpc=1&Ntpr=1
I really appreciate the feedback all, looking forward to doing some of my own work over the winter.
