Proper Petcock Flow
Proper Petcock Flow
I was curious what should the flow from a petcock be like anyone know of a video showing it. I know mine has crapped out but I need to know the correct flow. Should it be a nice steady stream coming out of a 1/4in inside diameter hose. or should it barely be coming out. I had mine draining and it drained very little I took it apart cleaned it up and it was flowing really good filter screen was clean. Test drove it still having problems drained it again and it was barely draining. I had the cap off of the tank while draining. I do not think mine is OEM I think it is aftermarket no vacuum line on my year. Just wanted to see what the proper flow should look like. I have a new one on order. I have a carb model not EFI.
TIA
Barry In MO.
TIA
Barry In MO.
This isn't real scientific, but here's how I would judge the fuel flow.
Assume you're running 80mph into a head wind and only getting 40 MPG. That means you'll need to flow 1 gal every 30 minutes, or 1 quart every 7.5 minutes.
Hook your petcock up to a piece of fuel hose and see how long it takes to fill a quart bottle. If it takes 6 minutes or less, I'd think that the flow would be adequate.
