amount of oil
amount of oil
I know this could be better posted in the oil threads, but I wanted input from fellow Sportster owners...
Anyway, now that I have learned a LOT about servicing my own bike through this forum and trying stuff myself I feel more confident about doing my own maintenance. I had to replace an o-ring on my clutch cable, so I adjusted my clutch while I had it apart & I also put Mobile 1 V-twin oil in the primary/chaincase to replace the syn 3 that was in it. It shifts so much smoother now & I'm going to change my engine oil to the Mobile V-twin now also.
So, my question is this....my manual says it takes 3.6 quarts, but when I had my dealer do the 10,000 mile service they charged me for just 3 quarts. I've read many threads about people using anywhere from 2.6-3.6 quarts....how much does it really take to have it at the full line when the engine is hot?
2007 1200C
2007 1200C
Para, your're talking hot with the bike upright & not on the jiffy stand correct?
As is it right now (dealer serviced), the oil when the bike is good and hot is right at the top mark with the bike upright.
Another question since I'm talking about oil again...does your Sporty consume any oil at all? Mine seemed to use a little (very little) when I bought it and was running on conventional oil, but since I have changed to syn it doesn't use any at all. Is it normal for even newer HD bikes to use a little or should they never use oil until later in the engine life span?
My sporty used a tiny bit of oil during the first 500 miles or so of the break-in, but doesn't use any now.
Ok, I just re-read my OM & it says when checking the oil cold it should be at the bottom mark when leaning on the jiffy stand, and when checking it hot it should be between the marks & if it's at or below the lower mark to add a quart.
So I'm assuming where you want the oil level is with the oil hot, bike on jiffy stand, level about halfway between the marks & this should be about 2 3/4 quarts if changing the oil?
I add 2.5 qts (counting what I pre-soak into the filter), let it warm up, check it, go for a short ride, then come back and top it off until it hits 1/2 way up the stick (on the jiffy stand).
I usually end up with about 1/4 of a quart left out of the three I start with, which I save for topping off the level over the next few thousand miles (but so far I haven't had to do any topping off post break-in).
I never check the oil for accurate level when on the Jiffy stand. I always check it hot with the bike straight-up. When HOT and STRAIGHT, the oil level should read half-way. Why check it on the side stand when you are riding, the bike is straight up. I bet if you checked your oil level when the bike was HOT and upright it would be right at the top of the dipstick and overfilled. Just my $0.02 I learned from a 25 year Harley Mechanic. He said the only bikes you should check on the side stand are bikes that have a swivel dipstick that leans with the bike. Sportys don't have a swivel stick. Makes sense to me. When I check it this way, my bike takes 2.2 qts each change.
Nope, I have checked it UP and on the stand and it reads within millimeters at the same level.
If I had anything like the condition you warned about, I'd have blow-by from the breather tube, which I do not.
