Lollypop baffles and torq cones?
Bump up from the depths...
I want to make up some lollypops this weekend. The commercial units I see for sale are solid, but I've seen them here with hollow centers (simple washers screwed/welded to the eyebolt). Is there an advantage to one vs. the other? What OD do you want the washer? 1200 sporty, stock slip ons with removed baffles.
You could also get some thunder torque inserts from DK Customs. These guys actually did dyno runs on their inserts and for ~$25 you get a quantifiable boost in torque through the whole range. Not just an estimate from someone's butt dyno.
Received 4,197 Likes
With the Thunder Torques you get more power at the same throttle, so less throttle is needed to travel the same distance. This equals better MPG in THEORY.
HOWEVER, most people like to play with the extra power, and no real increase in MPG is actually realized most of the time.
__________________
Win Up to $350.00 Cash from DK Custom This Month, Click HERE to see How!
DKCustomProducts.com
