X14IED question
X14IED question
I have a 2011 48 with rush slip on mufflers. The bike has popped ever since on deceleration. It sounds like backfire. I just bought some x14ied's and will install them as soon as I get them.
For future reference, I plan on getting some sort of intake for the bike. Will the x14ied's be enough for an intake, slip-on's and the stock tune?
Thanks for the insight!
I have the same exact set up at the moment. After installing the X14ied's the decel popping slowly started to go away. 500 miles after install and it rarely ever pops now.
I might try the Xied's when I get a bigger breather. I emailed Nightrider and they said the 2011 Sportsters are having better results with the Xied's. I found the X14's dirt cheap so I picked them up for the time being though.
another thought , would like to see some pics of the spark plugs , stock , xied , and different tuners ... would love to see whats going on with different combos
hold that thought , doesnt the xieds have a target ratio of 14.0 or 13.8 afr cross the board ?? while looking at the stage 1 download has 14.6 ratio on a huge board from 35 kpa up to 75kpa...
My personal opinion is that any pre-set stage 1 download is going to be sub-optimal, and ALL bikes should be custom mapped on a dyno with a wideband AFR meter by a competent tuner.
I have slip-ons, K&N cone AC and XiEDs. I had X14iEDs and traded them for the XiEDs as I didn't notice any improvement from the 14s. I could have had a bad set. With the XiEDs I still get some decel pop if I let off the throttle abruptly but it's not bad. The bike seems to runs pretty good.
I just got the X14ieds. I installed them the same time as my pipes, stock AC though, but no pop. I have to agree with 9x19 about the dyno tune. The ied's are not that, more of a stop gap. But for the $ Im not sure they can be beat. I went back and forth between weather I should get the x or x14 and decided on the 14. But a tuner and dyno time are in my future.
*edit* As far as I know the HD "stage 1" download doesnt change the AF ratio to keep the EPA happy. If it does its still way lean. I think it just changes the rev limiter and timing.
