What RPM?
Sportster RPM
That chart sounds about right for a 1200 running a set of 29/68 pulleys.
Keep in mind that some earlier Sportsters (especially 883's) came with 27t transmission pulleys, so they were revving quite a bit higher at highway speeds. They were great for quick launches, though.
Doesn't look like HD even offers the 27t pulley for the 2004-later Sportsters.
Before someone asks:
Since you do not have a tach to monitor when to properly change gears, here is an audio sample of my bike.
Key on: Bzzzzzzzzzzz.
Start up: Burrrurrrurrrrrrurrrrrr...
Idle: Pututta, pututta, pututta, pututta, pututta, pututta...
Take off: Burrrrrrummmmmmmm...
2nd gear: Burrrrmmmmmmmmmmmmmm...
3rd gear: BuuuuuuurrrrrrrrrrrrrrrrMMMMMMMMMMMMMMMM!!!
4th gear: Buaaaaaaaaaaaaaaaaaaaaaaaaaawaaaaaaaaaaaa!!!!!
5th gear: Burrrrrrrrrrrrrrrurrrrrrrrrrrrrrrrrrrrrrrurrrrrrrr rrrrrr.
Of course, I have a 2007 Nightster with Vance and Hines Short Shots, so your bike will sound somewhat different if you do not have the same setup as I do. Hope this helps.
Don't have a tach i just drive by feel/sound. I do know my rev limiter kicks in at 60mph in 2nd gear on my 883R. 45mph in 3rd and the engine is purring like a kitten. Most HD riders , ride with bogged down motors so they can get off on there put put muffler sounds . On 883 I never use 5th under 60mph. Silly bagger turned in front of me (Street Glide) and went from 0-4th never passing 30mph lol.. No engine likes low rpms.
cubcake1
11
05-17-2007 08:51 PM
