Removing Front Tire Problems
Has anyone ran into any issues removing the axle for their front tire?
I've got an 89 sportster that I'm trying to remove the front tire to take the rotor off and the axle will not go through the forks.
I've beat the snot out of it.
I've loosened / removed all bolts and I got nothing
Anyone ran into this problem and has a quick fix for me
I'd appreciate it
I'd appreciate it
How long has it been since the axle was last removed?
If it's been a long time and if the axle was not coated with anti-seize or grease the last time it was removed, the axle may be seized (rusted) to the bearings.
You can try spraying the axle around the bearings with something like PB Blaster and let it soak overnight. The go at it again with a bigger hammer.
+1 on the PB Blaster, I use Marvel Mystery Oil for everything, If you have any take a syringe and squirt a little on both sides on the fork lowers inside & out, then after it sets take a block of wood and put it on your axle and then hit it with the hammer the wood won't ruin your threads. Best Wishes. -Joe
