Sportster Speedometer Visibility
I have a 2005 Sportster 1200C Custom. The speedometer has what I would describe as a "sun shield" at the top which covers the top of the gauge covering the 45 thru 65 mph graduations. I have to crouch down to see the numbers when going this speed. It doesn't appear that you can rotate or remove the device and you can't adjust the angle of the speedometer in any way that I can see. Anyone have any experience with this problem and a possible solution or at least a way around it. BTW I am 6' 1" so I would think the bike would be set up for someone my height.
sbiermann
04-20-2015 11:36 AM
