'87 883 sportster rear chain
I have an '87 883 Sportster, no matter how many times I check and adjust my rear chain it always gets loose when I ride. I bought new rear chain adjusters through drag specialties and it still gets loose. Can anyone give me any suggestions to what might be my problem? Thanks.
If you're adjusting the chain too tight, it will stretch pretty fast. Or, if it's old and worn out (and/or the sprockets are really worn), it will stretch quickly. Another possibility is it's a cheap chain - they stretch much more quickly than a good one.
Im positive of the year. I adjust the chain to spec per service manual every time, so I know it cant be from being to tight. I believe the sprockets are original so I'm sure the teeth are pretty worn but none look to bad. The chain is only a little over a year old but it has sat in weather a couple times.
Thanks for the replies and suggestions fellas.
yosemite91
04-06-2017 12:23 PM
