High idle
High idle
Could this be possible ?? About 500 miles ago, I changed my oil from syn3 to Mobil1 20w50 for vtwins. Every since then, it seens like I have a higher cold start idle than before. After reaching operation temps, all is back to normal. maybe just my imagination, maybe not. Any thoughts.
Actually, weight/resistance is directly related to energy required to rotate mass.
I've had to drop the idle rpm on a vehicle by over 1000 RPM by changing to lightweight internals, and if you effect the resistance and friction in rotating or reciprocating mass by enough you will notice an difference.
With that said, I'm not stating that switching from SYN3 to Mobil1 would/did alter idle RPM, however it is at least a step up in oil quality.
