where im at on my modern retro
Old 12-02-2011, 09:00 AM
misput's Avatar
misput
misput is offline
Originally Posted by FLHT MAN
yep thats it..
Put your crankcase breather above the air cleaner or most bikes will eventually drip oil where im at on my modern retro-010.jpg
  #52
Old 12-02-2011, 01:36 PM
fixedmlc's Avatar
fixedmlc
fixedmlc is offline
could be ? its the small one...
It's stock on my 93. Also on the 94's as well.
  #53
Old 12-02-2011, 02:12 PM
bmxatv's Avatar
bmxatv
bmxatv is offline
Originally Posted by misput
Put your crankcase breather above the air cleaner or most bikes will eventually drip oil Attachment 219754
isn't that the point of the smaller filter to catch some of that blow by oil? where does the blow by go with this setup?
  #54
Old 12-02-2011, 04:17 PM
Voony's Avatar
Voony
Voony is offline
The bike looks good so far! Is that a special tire/wheel you put on to have the old school look? I am asking because it looks very clean and it seems that the tire is rather thin...or is that an optical effect because of the white wall?
  #55
Old 12-02-2011, 06:21 PM
misput's Avatar
misput
misput is offline
As the crankcase pressure escapes thru the filter the small amount of oil will separate and drain back into the engine. The oil can't make it up the hill. If you put the filter on the bottom, the oil will eventually saturate the filter and drip out. Gravity is working for you with a top installation. Against you on the bottom.
  #56
Old 12-02-2011, 07:39 PM
FLHT MAN's Avatar
FLHT MAN
FLHT MAN is offline
its just a stock size 90/90 21 made by Avon Venom-X , the rear is of a old shovel head fl ! lol..
  #57
Old 12-02-2011, 07:40 PM
FLHT MAN's Avatar
FLHT MAN
FLHT MAN is offline
cant do it , looks like hell ! lol..
  #58
Old 12-02-2011, 09:52 PM
misput's Avatar
misput
misput is offline
whatever floats your boat mon
  #59
Old 12-03-2011, 01:53 AM
Voony's Avatar
Voony
Voony is offline
Thanks for the response! I really dig your bike.
  #60
Old 12-03-2011, 08:53 AM
bmxatv's Avatar
bmxatv
bmxatv is offline
hmmmm.....thanks.
Quick Reply: where im at on my modern retro
