Pipes and air cleaner question?!
Yoooo guys! About to order a set of Vance&Hines shorties and a Joker air cleaner for my 07 Nightster. But what I'm confused about is what to do next... I've talked to Harley and they say all I need to do is buy a download from them and have it dynotuned but then others have said I need to buy a race tuner. This isn't something I know much about so definitely looking for some advice.
Thanks!
Thanks!
Right on that definitely helps! I don't plan on doing much more to the bike for performance... Anything else would be for looks. I've been told this makes a big difference on how the bike will run. But just so I understand... Is the purpose of buying a fuel pack to take the place of having Harley dynotune it?
You need to do something to account for the increased air flow. The EFI will adjust a little, but not enough for open pipes and a high flow AC. You have options, HD Download, Fuelpak, Power Commander...
I went with the Power Commander on mine because it's easy to plug it into a laptop and play with a custom map. This might be good if you change out parts later. The Download is a one-time thing. I haven't used a Fuelpak, but I hear good things about it. I'm sure there are other options, but these are the ones I know about.
If you go with a PC, I got a good deal on mine from Fuelmoto.
It will run like a new bike. I just set my OL up with a set up similar to yours. I went with the Fuel Pak,and it runs great. It is night and day from what it used to be. If you go with a FP,you can't fine tune with a dyno,same with a basic HD download. If you go with another tuning device,a dyno can help to fine tune you bike to get every last hp/tq from your set up.
