Chrome bolts or covers?
I can't stand that the bolts on the bike are not chrome or stainless!!!!
Should I go through the time and expense of changing them out to stainless or chrome or should i just get the covers to go over them.
Has anyone used the covers before. Can you get them back off with our breaking them, do they fall off?
RE: Chrome bolts or covers?
Well, it is totally up to you. The chrome bolt cover has a couple small fingers to lock the head of the bolt, it sits very tight. My buddy got a bunch on his softail for over 3 years, never fall off. You can pry them off with a small flat head screwdriver with breaking them. Of course it looks much better if you replace them all but it will cost you a bit. If you don't want to go for the Harley chrome bolts, many Marine shops carry stainless and chrome hardware, they are cheaper. Alex
I used the allen head chrome covers, check em out, most any dealer will have em. They hold well, snap on and off easy, and reuseable. Takes about 40+ in 3 sizes if you want to go wild. It would cost a small fortune to replace the bolts at the heads, case, frame, etc....
I've got every bolt head on this bike covered with Hottoppers. They fit nice and tight, but I still put a small dab of clear silicon in them before I slip them on just to be sure they stay there. They can be pried off easy enough without damaging them. I like the way they dress it up.
ORIGINAL: sporty1200c
Where did you get them from? How much $?
How do you put them on, do you push them on with your fingers or do you have to tap them on?
