My brakes worked fine changed my bars now the brakes wont bleed I've tried everything I can think of even off I remove the line at the cylinder no fluid comes out the hole
Master cylinder rebuild is required, and a thorough cleaning while it is apart. The feed port is a tiny pin-hole and it clogs easy... usually with deteriorating rubber from the piston cups.
When I changed my front brake line, it took forever to bleed the brakes. I thought something was wrong also - it just took a LONG time to get all the air out.
That being said, simply changing the bars shouldn't require bleeding the lines unless you somehow introduced some air into the system.
