need help changing riding positon
i have a 97 1200c with a mustang 2 up seat. when i ride for more than 1/2hr, the middle of my back starts to hurt, and goes downhill from there. i'm trying to figure out if i need to raise( get taller) bars, or just bring them closer to me(new risers). i haven't experienced this with my other bikes, just my new to me harley Any suggestions are appreciated.
Received 4,239 Likes
There are two things you can do.
This is the way that has always worked for me to get the most comfortable handlebar position-
Sit on your bike
Have someone hold it up straight for you
Put your feet on the pegs
Close your eyes
Put your hands out to where it is most comfortable to hold them
Open your eyes...where ever your hands are, that is where you want the handlebar grips to be.
Regarding getting a comfortable peg for your feet...you gotta have one that has a bit larger platform AND will move when you want to shift around a little.
There is a good assortment to look at HERE
Pic of just one of the styles-
Kevin
Sit on your bike
Close your eyes
Kevin
what bars do you have on it ??? I am 5'7 and 180lbs ,, I had the same problem,,I now have my bars ( buckhorn ) setting on the stock risers off of an 98 1200 custom,which are 5 or 5 1/2 inch riser,,that made it feel better then just the bars it's self,,I am thinking about going to the 16 or 18 inches mini apes,, because I think it would much better alittle taller,,,I still get some burning in my spine between my shoulder blades,,,I also have the small floorboards on my too,,I think there suppose to be for the passager but I have them up from,,I have small feet (8) so they work good for me,,if you would like to try another two up seat, I have the corbin seat,,I will be glad to send it to ya an see if that helps out any,,,that will give you an idea about if the seat will help your back out before you go buying stuff an it doesn't then you are stuck with something you aren't useing,,,pm me an let me know dude,,I'm eazy to get along with an would love to help you out if I can,,,by the way,on the seat you don't have to pay me nothing to get the seat an see what you think,,if you like it an want to keep it,,then pay me what you think it's worth,,I have 100 bucks in it,,,but it's doing me no good setting in the corner in the box,,,
I don't buy the lazy handle bar riding position when it comes to control or bike balance. Anybody that's ever ridden in the dirt on dirt bikes loves the handle bar position similar to buckhorn styles. I have my bar position similar to offroad bikes. My riding posture is vertical if not leaning slightly fwd. Having your legs under you is far better then riding your tailbone in every aspect.
Fwd controls are probably the worst riding position you could ever be in if you plan to go further then your local bar. Do the highway pegs option and don't limit yourself to fwds. I went from 250lbs down to 200 lbs. The ride at 250 was horrible. At 200 its actually not bad at all. Every bike has its limits in comfort and 50lbs of weight causes a major change in the way a bike rides.
Not saying your heavy just pointing out things that affect riding comfort and for me that was a biggie.
