09 Rocker Wheels on a 06 883c
Old 09-09-2011 | 11:33 PM
quan00's Avatar
quan00
Default 09 Rocker Wheels on a 06 883c
My brother just upgarded his wheels on a 09 Rocker C and gave me his factory wheels. In my haste i bought new tires for the wheels and realized today that the shaft size for the front is different between bikes.
Can I use these wheels on my bike? I know the rear will require a wide tire conversion. Will I be able to install 06 883c bearing on the wheel for the 0.75" ID shaft? Will I need a spacer since the ID of the wheel where the bearings doesn't sit is larger than .75"? Same questions apply for the rear except I think the rear is 1.00" ID bearings for the Sporty (not sure what it is for the Rocker C) Any help would be greatly appreciated! Thanks!
Old 09-12-2011 | 11:09 PM
quan00's Avatar
quan00
Turns out this is going to be a little cumbersome. For the front rocker wheel to take a 0.750" shaft I could do 1 of 2 things, (1) machine a bushings to fit into the 25mm ID bearing to change it into a 0.75" ID or (2) machine each side of the wheel where the bearing sits to take a 0.75" ID bearing (which has a thickness of 21 mm) in place of the 25mm ID (which has a thickness of 15mm).
Dammit HD, why couldn't have been an easy bearing swap??? That I unless someone knows of a another solution.
SoCal_FXDLS
12-15-2017 01:24 PM
Alain
09-15-2014 06:44 AM
Rail
06-17-2013 03:43 PM
masar
03-11-2010 09:11 AM
jameymiller00
02-05-2009 07:27 PM
