primary oil change
primary oil change
Changed out the primary/tyranny oil today with Mobil1 75w90 (switched from Amsoil 20w 50) but can't really tell a difference from initial test ride.
A couple questions though...the gear oil started dripping out towards the end of the quart on the jiffy stand so I'm assuming you have to have the bike level to fill it with the whole quart?
Also, any down side of just pouring the oil through the primary chain inspection cover? Taking off the left footpeg to get the primary cover off is kind of a pain.
Manual states (for the new sporty anyway) the bike must be level (a 2x4 under the jiffy stand gets it very close to level), and the fluid should come up onto (but not above) the bottom most teeth on the large primary chain drive gear.
Mine took almost exactly a full quart, I think I might have had 1 ounce left over.
Be sure to clean the shavings off of the magnetic drain plug if you have a magnetic plug.
Kind of like this:
