From efi to carb????
haha i do ride the **** out of it, ecu failure is my last concern, main reason is clean up wire cluster , make the bike simpler , and remove my side covers and replace my stock oil tank.. i got a vision in my head of it .
The bundle of wires can be minimized quite a bit and they WILL fit in the backbone. I swapped a Buell from EFI to carb. I used a Mikuni carb, Screamin Eagle ignition in the cone, VOES and basic wiring.
It sounds like you've already convinced yourself to do it...regardless of the input you're receiving here.
Yuck! I avoid buying anything with a carb if I can afford it.
As to tuning, why bother? If you find a decent tuner, how often do you think you will tune it? Certainly not on a daily basis. EFI can adapt much easier than a carb and does not need to be tuned for each change of condition.
i tune as far as engine mods will go, im always looking to make my bike faster, im currently using a tuner wich my bike is running decent off of but it can deff be better ,, another reason, ive had carberated bikes my entire life and i can work on them i cant work on no ecu
, and i will never let someone else work on my bike , its just a thing i have ..
