Charging system troubles
I have an 87 1100XL and I'm not getting the correct charging voltage when I rev it up. I've checked the stator for a ground and for shorts, everything checks out OK. The manual says that it's the regulator. OK, I replaced that. Still when I check the voltage at the battery I only get 12.95 volts across the terminals.... I should be getting 13 or more.......I'm stumped....am I checking the charging system wrong?
Checking Correctly!
With the bike off, you should get a volt reading (at the battery) of about 12.9 volts. A 12.7 volt reading is approx. a 1/4 discharged battery! With the bike running you should get approx a 14.3 to a 14.5 volt reading. That is a proper charging rate.
It is in fact that simple!
Under a load (lights on or controled short with a load tester), with the bike off, the battery should be able to maintain approx. 12.9 volts. If the volts drop off to fast the battery needs replacing. The first test to check the battery is always to make sure it is fully charged and then load test it.
It goes above 22vac when revved up.I wasn't paying any attention on how high it was going just that it was within specs according to the tech manual. I spoke to my son who has an 85 sportster and he had the same problem and he replaced the battery.......Dad, "replace the battery"! Did I mention this is the son that went to a Technical college for auto mechanics with an Associate degree and majored in electrical diagnostics.........we will see if my money was well spent on his education!
MachineX
Electrical/Lighting/Alarm
09-05-2014 09:25 AM
