So how do I know if I need mroe backpressure?
So I just went to some Rush slip ons and they sound great. But sometimes at idle it sounds and almost feels like a v8 sounds when it isn't firing on all cylinders (misfiring/skipping a cylinder once in a while. I dont think it is, just a factor with the new exhaust). Is that a symptom of [lack of] back pressure? Only sometimes from a dead stop does it feel like its 'doggin it'. What are the symptoms of lacking back pressure?
The Rush baffles are held in with a 3/8s nut and bolt, so I could put some eye hooks "lollipops" in quite easily.... if I need to.
Thanks in advance.
Thanks in advance.
what year is your bike? If you have 02 sensors, you can buy a handheld wideband oxygen meter for under $200.
I bought for tuning 4wheelers. You can use em on anything with a bung in the exhaust. With that being said, you can have a o2 bung installed in your headpipes and can tune everything!
http://cgi.ebay.com/ebaymotors/AEM-W...item3a6193fd18
I meter backpressure with a vacuum gauge. If it pulls 0.5" at idle and 1" at high rev it's spot on. I measure every pipe I make to ensure proper back pressure. If it's low I'll insert dowels throughout until I reach the reading I want. I've never ran in to a situation where it's too high.
I drilled a hole in an oxygen sensor plug to thread in a fitting. The line from my vacuum gauge hooks to that fitting. Run the bike and watch the gauge.
On non-efi bikes I drill a small hole for the line fitting.
Really though, you don't have anything extraordinary. I doubt you have a major problem. A baffle or lolli-pop insert should smooth your out. Or maybe some torque cones.
YOU being the o.p.
YOU being the o.p.
YOU being the o.p.
YOU being the o.p.
I had a fall on it's face popping hesitation about 3000 rpm when throttle was opened rapidly under a load, installed one size larger high speed jet, did not help much or at all. Installed lollypops and almost got rid of it but still has a slight flat spot about 3000 rpm. Would a vacuum test show whether I need more baffling.
What is a line fitting? Can you thread it in back where a lollypop would go or up near the head? Will it read the same no matter where you install it?
I would bet you have a lean fuel problem. Restricting the exhaust some will richen it up a bit.
Yes, metering your exhaust will tell you if you are having a back pressure problem but like I said, your problem sounds like it begins at the carb.
Or it's the nut that connects the throttle to the seat.
Lol, sorry, I've always wanted to say/type that.
