Broke the spring pin for the kickstand
Took a ride at lunch and passed over a curb leaving a parking lot. It's one where they never tapered the curbing when the lot went in. Anyway, the bike bottomed out and the kickstand hit the ground and started dragging.
I stopped and found the kickstand spring lying on the ground. I used a bungee to tie up the stand and went back to work. When I attempted to reattach the spring, I found that the spring pin on the frame apparently was sheared off (see pic).
I called the indy and his only suggestion was to fabricate a pin and / or weld something to the frame. Obviously I'm open to suggestions on how to repair it.
That pin comes out dude. Unless someone welded it, check it out here. Your manual should be similar (this is a 98), unless the '04 is different but can't imagine that it is.
http://partsfinder.onlinemicrofiche....=13&A=175&B=30
Happened to my wife's 08 nightster too while loading it in the uhaul from the guy I bought it from...
I called a welder friend of mine. Took a screw with a head and cut it to length and butt welded it to the little tit on the frame. Works great.You need the head on the screw to keep the upper spring hook on. A Tig/Wire Welder works well. Someone will have to hold the bike at an angle to get too it...We ran mine up on an oil changing tire ramp for cars at my house, then leaned the bike over and he could get right to it...I know all this having just done the repair two weeks ago.
Now...Harley makes a "Special Tool" that is a guide for a Tap and Die repair so they can drill the little tit, tread it and put a "Harley screw" (how appropriate) in the threaded hole. I was gonna do that but Harley charges 201.00 to RENT the Super duper guide device to drill the hole. Since my Stealer had never done one and I did not want them to do mine, and I calculated that LABOR of 150.00 + 201.00 to BORROW the tool was going to approach 400.00 bucks I decided to do it myself. It cost me 40 bucks and a round of beers in my garage. (I paid the friend for his gas and trouble since he lived about 40 miles away). Hope this helps!
Excuse the crappy cell phone pic!
