Need about 2" pull back on the Iron 883...how to do this?
Old 09-07-2011, 11:58 PM
parabellum_9x19's Avatar
parabellum_9x19
parabellum_9x19 is offline
That is a cool riser setup Swamp!
I wanted something cheap and functional, so my kit is just a set of milled aircraft aluminum spacers powdercoated black, they go between the riser block and the top triple.
They would be on by now if it weren't for the stupid front brake line issue.
Old 03-18-2015, 01:50 PM
Roorat60's Avatar
Roorat60
Roorat60 is offline
Red face 4 in curved riser kit 56066-82A OEM
Hey gang! I'm new to the forum and to riding a Harley. I own a 2014 Iron XL883n and have ordered the genuine HD curved riser kit 56066-82a, so that I can get a little bit better reach. I already replaced the stock seat with a solo reduced reach, which helps, but I need a little more pull back so my arms aren't out straight. I hope that I won't have to replace any cables and the specs don't say anything about needing any. Can I expect an easy swap out on these? Any advice from the vets?
Thanks.
P.S. I sure wish these things came in black, though.
Old 03-18-2015, 10:43 PM
sroc3's Avatar
sroc3
sroc3 is offline
Thanks.
I installed these bars that have the perfect sweep back for me - #56085-83A
Old 03-19-2015, 12:21 PM
Roorat60's Avatar
Roorat60
Roorat60 is offline
Default Handlebar suggestion- thanks :-)
Do you have an Iron 883? What year? There's not a lot of stuff on the HD site for my specific bike, unless you know what will work for other models . I think this bar came standard/stock on the 883R, but that's European, right?
If my risers don't work (too late to cancel order), I'll look into the handlebar for sure. Thanks for the suggestion.
Old 03-19-2015, 06:44 PM
Mick's Avatar
Mick
Mick is offline
The Iron bars spec the same as a '48 model.
The 56085-83A is stock on the XL1200N , XL883R , and , XR1200.
Here's a link with measurements.
http://www.sideroadcycles.com/Import...ckBarsOne.html
Here's a couple pics showing the difference.
Doesn't look like much , but feels alot different when riding.
If you make a fist then knuckle to the grip and move it to about half way out the grip , you get an idea where your hands end up.
They go about $79.00 at the dealer.
Stock brake line "just" fits with a little tweak.
Mick
Old 03-20-2015, 10:12 PM
Michael Ficken's Avatar
Michael Ficken
Michael Ficken is offline
I put on the mini apes with my iron, one of the best mods I have made. I did have to replace brake and throttle cables. The clutch cable will work but I replaced mine.
Old 03-21-2015, 09:39 AM
Switchback12's Avatar
Switchback12
Switchback12 is offline
I used DK 1.5" extensions on wife's 11 iron, no changes had to be made, did the trick.
Old 03-28-2015, 01:41 PM
Roorat60's Avatar
Roorat60
Roorat60 is offline
Thanks.
Update.... Need help!!!
Ok, just got the risers and installed them. Just what I needed for pull back and reach, but...now the speedometer is vertical and can't be used/seen. What are my options for being able to keep the risers on AND seeing my speedo?!?
Old 03-28-2015, 03:41 PM
HarleyScuba's Avatar
HarleyScuba
HarleyScuba is offline
There are a few pics in the other thread (I tried to warn you).
https://www.hdforums.com/forum/sport...-for-iron.html
One guy used sockets as extensions and another guy re-purposed a pair of cable clamps to attach an older style speedo bracket. Those bikes used bulbs for dummy lights. The newer ('07 up) bikes use LEDs instead of bulbs. In 2014, they went to a CANbus system, but I'm not sure what influence that will have on dummy light components. You gotta figure out what parts you need to get your dummy lights into some other style of speedo bracket. After market components, that don't have the bend in the speedo bracket (eliminating the vertical orientation), are available, too, that would permit mounting your speedo to your present risers. A different handlebar clamp, widely available in many forms, would be required for any of the above options. Again, the trick is transferring your dummy lights to a new arrangement. Different components for the dummy lights, the lights' housing and the lights' lens are used for different Harley models/years. You just gotta match up/customize something that'll work.
Go here and look up your bikes assembly diagrams with part #s:
http://www.shopronniesharleydavidson...FZMkgQodQ4sAUg
Click on "OEM Harley Davidson Parts Finder" in the top menu, enter your bike's info, scroll down (under the Frame heading) and look at "Speedometer Assembly". That'll show you whatcha got. Then, find what you'd like it to be and make it work.
A modular system allows you to get the handlebar clamp you want, then attach the speedo clamp you want on top. An example, from J&P Cycles Catalog:
http://www.jpcycles.com/product/632-395
and
http://www.jpcycles.com/product/632-420
A few manufacturers make kits that relocate your speedo/dummy lights to the side of your gas tank. Probably not what you're looking for, but they're an option. Joker Machine, for example.
Lots of options to explore. Look around, before you get too fixated on one solution. Try a Google Images "Sportster Speedometer Bracket". See if something jumps at you and post it here.
Old 04-08-2015, 12:17 AM
kx2's Avatar
kx2
kx2 is offline
6th Gear
My speedometer mount lays a little flatter than stock.
TSAVO
03-19-2015 12:26 PM
volks-man
05-19-2014 06:03 PM
XjldX
07-26-2012 09:41 PM
pibpd905
08-17-2011 03:38 PM
beringer
12-15-2010 05:09 PM
Quick Reply: Need about 2" pull back on the Iron 883...how to do this?
