wrapped the pipes and lowered the rearend
i finally broke down and wrapped my 2into1 blackouts. they were way too hot without heat shields. the wrapped has cut down on the heat significantly and i like the look more than i thought.
i also added burly rear shocks to lower the rear end. i bought the whole kit and have the springs to lower the front, but i don't know if i going to do the front. i kinda like it the way it is. any thoughts whether or not to lower the front end?
I like the front end as is.
Further more...Your bars look good too.
What did you do for riser & speedo?
Kinda hard to see. It all looks good man.
I just started a thread today about apes on a custom.
I'm w/ you. Didn't to wrap them but they were too hot and i really like the look. I used hd wrap. I let it set up until it totally dried. I went for a two hour ride and it smelled like *** and smoke for about an hour.
Imo any bars other than stock and some drag bars look bad on the stock custom riser. I used biltwell slimline risers and and rsd speedo relocator and idiot lights. The rsd was expensive and presented some fit issues, but i like the speedo low and in front of the bars. The bars are biltwell friscos. They're great, but you have to drill them yourself to internally wire them. Not hard just a little bit of a pita.
