How to disassemble turn signals on 48
Old 08-17-2011 | 04:19 PM
Chessman.exe's Avatar
Chessman.exe
Default How to disassemble turn signals on 48
Has anyone done this successfully to get them powder coated/replaced/other?
Ive tried nearly everything to get the reflector out of the housing, but it is nearly impossible to do.
I have even taken the entire assembly off and unscrewed the nut behind the stem, no avail. How is this done without cracking the reflector or breaking the rubber gasket?
Old 08-17-2011 | 05:33 PM
JRK5892's Avatar
JRK5892
do it every day man... i like to cut and solder my wires as it is easier... simply pop the lense off you can use high compressed air from the stem to pop it out or reach in bet a small screw driver in around the rubber to remove them
if you are not comfortable we charge $25 per signal to coat in any one coat powder (like black) and can do full tear down and re assembly with soldering for $15 per lamp
Old 09-05-2013 | 09:43 PM
herberaw's Avatar
herberaw
5th Gear
How does the stud come out of the turn signal housing? I tried using an Allen wrench but it feels like it is going to break off????!!!!!! Thanks
JackHoleRacer
04-29-2019 12:17 PM
nh bill
EVO
02-23-2017 09:10 PM
skullbob
02-26-2013 02:20 AM
Chessman.exe
08-11-2011 01:19 AM
airbike
04-02-2011 10:04 PM
