Anybody got friscos on the bike?(witch brand) pics? Cables and internal wiring (fit)? Brake line (fit)?any info and pics would be great
Friscos are made by one brand, Biltwel. the dont come drilled. When I got mine I had to drill them out, and run the wiring...ONLY WIRING. I did not run the brake line nor the throttle cables...Im not sure that they will fit without modifications or with mods for that matter.
I ran all the switch wires only.
also, the brake like has a metal hose that goes from the brake lever and joins the rubber hose for the rest of the line....this metal hose will need to be bent a little in order to fit properly in the bars depending on the position you like...it was inevitable for me....
another thing is...when running the wires, I cut the ends (connectors or "plugs") off and ran the wires through...much easier...then just solder the connectors back on...I added an extra 2 inches of wiring to be safe so I really cant tell you that your not gonna need to extend the wires..
Hope this helps!
Yes it helps I didn't mean run brake internal only switches road custom makes some now also. I've got 12" z bars I was gunna put on but I've got to buy burly kit so was thinking of just going with frisco
