effing stator
effing stator
I planned to take off after work tomorrow and cruise over to Jackson hole, spend a day or two, but I had to push start my bike this morning. Battery checks out fine, so it is probably the stator or the voltage regulator.
I read some stator threads, and have pretty much decided to go with the cycle electric CE-9100 or the ACCEL. I'm definitely not going with the Harley OEM part.
Can you guys that have done this chime in and let me know if you have had problems with those parts? Also, is there a way to check the voltage regulator? If it is just that, it would be a lot faster fix.
Thanks for your help.
2004 xl883
2004 xl883
Last edited by tjae; 08-11-2011 at 08:40 PM. Reason: You probably need my bike info to help out.
Hopefully cHarley will chime in. He has those numbers memorized. Its odd you didn't see where he gave those numbers in other posts.
But you will have to put your year bike.
Id go back out to the shop for the book, but mines a ridged mount. Plus I'm a lil heat whooped from wrenching a KZR1000 back together.
I've changed out voltage regulators & stators before but not on harleys ...I'm sure the process is basically the same.
The first thing you need to do is get your bike started and rev it up to about 2500rpm and then using a meter measure the voltage at the battery. Should read about 14 volts DC. If you're are getting 14 volts then you charging system is probably not the issue. BTW, you said the battery tested good...a good battery should measure 12.6~12.8 volts with ignition off, was that the case?
Found cHarley's post. Pretty sure it is the Stator. a Local indy has the CE-9100 for $100. I can get some cheaper on eBay, but you guys have said good things about cycle electric, so I'm going with them.
I saw that you put in a CE Stator. Good results? I think you changed out the regulator too?
I helped my brother changed the stator on his Vulcan900 a couple of weeks ago. Reading through the service manual, it seems mine is going to be quite a bit more complicated. We will see when I get the primary cover torn off.
Alright. A local indy is holding a CE-9100 stator for me until morning. I have a question though... The manual says I need to pull the clutch assembly. I can't figure out why I need to do that. This write up
https://www.hdforums.com/forum/sport...ghlight=stator
the clutch assembly wasn't pulled. I am leaning that way. What do you think?
