diy derby cover in black
Question about powder coating: I did what Ken did and painted mine flat black. It looks great, much better than stock imo, but the flat black paint does scuff up quite a bit, especially as mreed notes with mid controls. The paint doesn't come off, but when you rub against it, it changes color slightly and looks, well, scuffed up. Is that scuffing inherent to flat black finishes? If I powder coat something flat black will it do the same thing or does it hold a more consistent color than flat black paint?
i think i'll go with several more layers of paint and maybe rub it all of and start with some primer.
if all else fails i'll go for powder coating. but i wonder if i can ever get that matte black look with it.
Two drawbacks to Duracoat: 1) It ain't cheap. A 4 oz. bottle if you have your own airbrush to apply it is $16.95. But 4 oz. will actually go a long way. They also have a complete shake-and-spray kit with an aerosol sprayer, paint, degreaser, etc for $29.95.
And 2) Duracoat requires about a week to fully cure to maximum hardness. You can handle it after an hour or so and after 24 hours it's as tough as regular paint and you can reassemble, whatever. But you need to give it at least a week to achieve full durability.
I used it because I had a small amount that was going to end up going to waste if I didn't do something with it. But it does appear that the flat black Duracoat is much better at resisting the scuffing you get with regular paint. So in that regard the extra expense and time might be worth it.
Hence, my original question regarding powder coating - will the flat black powder coat resist the scuffing problem you get with flat black paint?
goinsideways136
07-11-2010 07:13 AM
goinsideways136
08-24-2009 08:35 PM
