Trouble with my Sporty...
This morning my Sporty didn't wanted to start. After about 15 tries it started. Buy now when I hit the throtle it dies. The bike was running fine until yesterday, the only thing that i did was wash it and didn't started it until this morning... What could be the problem? It idle well but die with a movement of the throtle...
Thanks in advance for any light that you guys can give me...
RE: Trouble with my Sporty...
Could be alot of things, don't panic, I've had the same issue. Is it very cold, say below freezing? Did you have spark? How much did you pump the throttle? battery strong? How far did you pull the enricher/choke? Flooded? Fouled plugs? etc... For mine, I have to give the throttle 2 half pumps, pull the enricher about a quarter way out, make sure it's in neutral (not with the clutch pulled in unless it warm), and not romp on the throttle untill warm. Usually about 2 to 4 min. then ride easy for a bit. Any help???
Treyben
10-17-2012 09:11 PM
