New tire and brakes.
This will be my first attempt at installing a new front tire and brakes on my sportster.Sunday i got the front tire and front brakes off.Now im just waiting on the new tire and brakes to get here.Wednesday hopefully!!Although the back brakes look like a different story !Any you guys know if i can remove the rear caliper without removing the rear axle?
Just be nice to know before i get started on the rear.
Thanks in advance!
Thanks in advance!
I've changed the rear pads with the tire on and off. For me, I've found it a much easier job with the wheel off and out of the way and now just schedule the rear pad changes when I'm replacing the rear tire.
The Fix My Hog DVD does a good job of showing you how to replace the pads with the wheel on though, along with all the other standard service procedures. A good buy IMO at $42.95.
Thanks for the info.I've already broken loose the pad pins(the ones that hold the pads in place) on the rear just to see how tight they were gonna be.As for the rear caliper i haven't tried to break it loose yet.I will be giving it a shot tomorrow hopefully if all my parts come.Is it necessary to re-apply loctite while reinstalling the pins?As for the front axle should i apply anti-seize or high temp grease before i reinstall it?
I must say it was fun finding a 12 point socket to fit these small pins
The pins get anti-seize not Loctite. I also prefer anti-seize on the axles instead of grease. Axles that I put anti-seize on 70,000 miles ago, have never needed to be re-coated even after many R&R's. Grease works OK, I just think anti-seize does a better job of staying put.
Check your PM Inbox in a couple of hours, I'm sending you some more useful info. Don't disassemble anything else until you get the PM.
Yes i know.I just didn't want to break loose the caliper yet.I will do the rear after i get the front done.Just want to make sure i could get the pad pins loose before i removed the front tire just in case i had to take it to the shop.I have many years in car mechanics but never worked on a harley.Just want to do it right the first time..
It won't let me receive a PM yet..Your welcome to email it if you wish.
woodsytattooman@gmail.com
Looks like the admin has to do something for me to send and receive private messages.
