Sporster Choke
Sporster Choke
I have a 2005 Sportster 1200XLC and I just got my 15K tune up, and when I make a full stop, with engine at normal riding temp, when I release the clutch and turn the throttle the I get a puttering/choking feels like its running out of fuel, no forward movement, if I throttle more it back fires then rev's normally, this happens each time I make a full stop and only after the engine is warm. I am new to riding and I would like some feedback on how to fix this problem.
Sounds like you've got a little crap in the carb. Pilot jet might be partially clogged. Those carbs are relatively easy to work on. You can run a cleaner through it without dis assembly and it might work, or you can pull the float bowl and clean the jets. Check on You tube for some vids on the operation.
Sounds like the crank position sensor... they are prone to failure and will mess up the spark timing as a result, usually after the engine is warmed up. Buy one and replace it yourself, it is a ten minute job. Located below the oil filter in the front of the crankase, one socket head cap screw to remove and an electrical connection to unplug under the frame.
remove the airbox, shoot some carb cleaner in there when running it. rev when you shoot it in, it will want to die.
I did this on my older carb bike... forgot to winterizzz.. oops.
But ya sound like a clogged needle. or this is what is was for me. this worked mostly, but mine was really clogged.
If that don't work, craigslist workes. dude came over, pulled carb, took it and cleaned it. $30
Hey will only do so much.
