avon grips
Old 07-27-2011, 03:40 PM
gfburke's Avatar
gfburke
gfburke is offline
Default avon grips for 48
just about to place an order. wanted to verify these are the right ones for a Forty Eight.
http://www.amazon.com/gp/product/B00...A3TGC5XRRCX4P2
Avon has a few that looks the same, but some are "push/pull throttle" and some part model #s don't.
thanks
Old 07-27-2011, 04:07 PM
gfburke's Avatar
gfburke
gfburke is offline
ug.. for realz?
Old 07-27-2011, 05:08 PM
gfburke's Avatar
gfburke
gfburke is offline
Well, called avon. (that doesn't sound right..)
This item is right assuming the 2011 48 uses push/pull throttle.
The girl said push/pull is for older bikes.. and the fly by wire is for newer bikes.
so.. do i have push pull? i think i do since i can see cables. and with fly by wire that means all internal wires.. right?
Old 07-27-2011, 05:51 PM
Ragnar Danneskjöld's Avatar
Ragnar Danneskjöld
Ragnar Danneskjöld is offline
Well unless something changed in the 2011 models (which I doubt), then you have push/pull. Easiest way to make sure is to open the control housing and slightly pull the grip out. If you see two cables, then you have push/pull.
Old 07-27-2011, 07:19 PM
gfburke's Avatar
gfburke
gfburke is offline
thanks man. i'll just order up and assume nothing has changed.
my google powers are about as good as they get and there is just nothing coming up.
this dude lists "2010 Harley-Davidson Sportster Custom - XL 1200C" as compatible for this part #.
Old 07-28-2011, 07:49 AM
mwegryn's Avatar
mwegryn
mwegryn is offline
Should be good to go, aren't the touring bikes the only ones with fly by wire right now?
Old 07-28-2011, 08:26 AM
HERE's Avatar
HERE
HERE is offline
I believe the touring bikes are the only ones using fly-by-wire. Everything else(Sportster included) is push/pull.
Old 07-28-2011, 10:42 AM
bmxatv's Avatar
bmxatv
bmxatv is offline
you got push pull bro....two cables. my boy dubbl_r has them on his bike, they're sweet. comfy as hell.
Old 07-28-2011, 10:52 AM
gfburke's Avatar
gfburke
gfburke is offline
tight, thanks guys.
yeah, felt them at the dealer.. damn near wanted to sleep with them.
damn, they just raised the price $10 since yesterday..
G|man
05-15-2018 03:21 PM
Tek74
08-03-2014 05:48 PM
mudder
10-20-2011 05:35 PM
CYCLE
04-09-2011 01:09 PM
missile
03-15-2011 10:50 AM
Quick Reply: avon grips
