Anybody using Lepara seats?
Just got my Mustang wide touring solo seat delivered yesterday, put it on the bike and found it sat too high for my liking. It's getting returned. Was looking at the Lepara seats, and they look pretty nice. I had Corbin on my previous bike and liked it, but I don't think the gunfighter profile would look as good on a Sporty. Anybody have experience with Lepara?
I have the Silhouette 2up and I really like it.
I like the fact that you don't have to remove the mounting post used for the stock seat to install the Silhouette, they just shape the steel base plate to fit over it. The vinyl they use for the cover is shiny. (they have a leather too) I like the tapered sides, and it sits me at just the right height.
The Silhouette hugs tight to the frame, which means there's not a lot of padding in some areas. I wanted a seat with a bit of a lip in the back (seat manufacturers always call this "back support", but I don't see how that could support your back. I call it, "keeping me from sliding off the back of the seat support"), and the Silhouette is perfect in that respect as well.
Having said all that, I have also owned both the HD Sidekick and the Bandlander. I believe the Sidekick is actually a tad lower than the LePera, but both sit you back about the same. The LePera feels lower than a Bandlander and probably about the same as a stock solo seat on an 09 Iron.
On a side note: I recently bought a detachable sissy bar, and the backrest pad Harley sells uses the same matte finish covering that all their seats use, which in my opinion doesn't look good with a shiny LePera seat. LePera doesn't sell a compatible backrest pad but was willing to re-cover my Harley backrest pad in the same material as their Silhouette, so I sent it to them. I thought it was pretty cool that they'd do that for me.
Did you have to remove the seat post for the bare bones?? The reason I ask is that I use leather throw over bags that use the seat post to keep them from slipping to the low side when the bike is parked.
Blink I've been considering this exact combo. I don't see a pillion pad option on the LePera website, although they do display a few. Did you simply call them and tell them what you wanted regarding the pillion? Can you ball park the cost. Also, how do your passengers like the pillion? My wife is pretty particular about her comfort level. Thanks.
"Hey guys, i have recently fitted a Lepera barebones LF-006 (04-06) seat to my Iron (which is basically bolt on), then i looked at a pillion option for my miss's, it seems that Lepera do not make a pillion for this kind of setup, so i did some looking around and a little measuring and even spoke to Lepera themselves, and it looked like the L-006P would be the closes fit. So i went and ordered one, upon arrival i noticed that all i needed to do was make a new rear bracket for it and it would fit, the Iron's bolt hole is 40mm further than what came with the pillion seat, so an easy task it was, i found some spring steel (nice and strong) and bent/cut/drilled for 15 minutes and hey presto it fits. I decided to paint it matt black and will look at getting it powder coated some time in the future."
