Flipped Bars
Flipped Bars
I flipped the stock bars on my 03 sport and I'm having a problem with the throttle cables. The throttle sticks some when i twist it. It seems like they might be too long, it feels like they are in a bind. When i take the throttle assembly off the handlebars and the pressure is off the cables it works fine. Has anybody every had this problem or know a good solution?
After you flipped them, make sure there are no burs or rough spots on the throttle side of the bars. That side used to be on the left side of the bike and was not meant for the throttle. I found I had to take emery cloth to my new throttle side and sand it down to make sure it was smooth and the throttle wouldn't stick. Weird thing was it wouldn't stick when I just slid it on, but as soon as I got tension on it with the throttle cables attached, it wouldn't snap back. Once I sanded, worked smooth as silk. Good Luck!
