How short of struts
Received 4,196 Likes
10" is about it. We have a few customers that have gone an extra 1/2 - 3/4 lower, but they also took care to re-route the wires that are on the inside of the fender.
Kevin
HDForums Scavenger Hunt Contest
Kevin
I made mine. 9.25" eye to eye but are adjustable up to 12".
Here's another set I made just the same
But you can make your own with your stock shocks.
Here's a set I did for my mock up bike
Disassemble the stock shock
Drill a small hole in the bottom of each one to release the pressure so you can tack weld them closed
Those should work perfectly fine but I didn't ride on them because that bike ended up this way instead
Punk09Rocker
06-01-2010 07:18 AM
dyna mo
01-09-2009 08:34 AM
04, black, coil, harley, ironhead, motorcycle, motorcycles, relocation, short, shovelhead, spitfire, sportster, spring, struts, sturgis
