No Longer Stock Sportster
RE: No Longer Stock Sportster
Oops! Forgot the link. Geezerhood strikes again.
http://i85.photobucket.com/albums/k5...3/DSC00855.jpg
Hey Douge_2000,
I thought it went relatively easy. I'll ran into a problem or two like I had to cut the carb backing plate off to get the breather screws broke loose with a pipe wrench. Needless to say that destroyed the screws. The SE A/C kit had it's own backing plate so it was an easy fix. Before you start, you'll need: HD Service Manual for your bike. This is a must do. A good SAE socket set with deepwells, Torx bits set up to 50 that fits your socket drive ..you'll need up to 45 for the conversion but a lot of the Sporty fasteners are 50 . You'll need a 16 point 1/2" socket and a breaker bar ( I used a piece of pipe) to break the head bolts loose. Also a torque wrench up to at least 35 ft/lbs The conversion I bought was at EBay $426. A top end HD gasket set $90. Don't try to reuse gaskets..replace all you open up. Small tubes of assembly lube & Loctite Blue. New Allen wrench set and I also bought a 3/8 drive allen set. I took a week on & off but could have done it in a long day or two regular days. I took my time primarily so I wouldn't miss something. If you're going to rejet for the 1200cc replace those carb screws with socket cap screws.
Hey, it was a hoot. The neighbors have mixed feelings about the V&H pipes. Follow the manual and the directions that come with the conversion kit and it'll go sweet.
Olesalt
Anyone have any questions post 'em or email me olesalt43@***.net
Olesalt
Thanks for the info!
I've got everything you mentioned that I'll need except the conversion kit and the 16pt socket. As I read more, I'm getting comfortable with doing it myself. I've learned that I like working on the scoot - did all the stuff in my sig myself. Did a lot of engine work on British cars in a former life. Plus I figure I've got the forum as a backup.
BTW - what should I tell my wife I'm doing? It was a chore talking her into the Harley. She doesn't ride anymore and I'm sure she's going to ask why my new bike is in pieces in the garage.
Theres a lot of info on the Sportster Pages http://www.sportster.org/tech/evo-tech/heads.shtml or Nighrider.com
http://www.nightrider.com/biketech/x...200_page00.htm. Unfortunatly I can't help you with your bride. My kit and V&H pipes were an early Christmas present.
