my 07 1200 c was running fine then suddenly just quit. have power to everything except fuel pump. it will not pressure up. checked fuses and they are ok, checked fuse block and have power to all fuses except fuel pump. any sugestions?
no ..this is not a bad joke. all the fuses are good and all the systems have power including the security system. the only circuit that is dead is the fuel pump. no power ay the fuse block.
thanks for posting the how to article on diagnostics codes. this is something the dealer will not tell you. According to the article --- it is showing both fuel injectors are in the open position...code p0261,p0263 and system relay coil open/system relay cantacts open code p1001/p1003. this gives me a better idea of where to start looking for problems thanks again
