Screamin Eagle Slip Ons with stock air cleaner
Hi,
I am getting a new 2011 48 in a month. I want to install Screamin Eagle Street Performance Slip-on Shorty Dual Mufflers (Part# 80726-09A) on my bike. I am told by some friends that I WILL have to change the air cleaner to a Stage-I or Heavy breather to go with it.
Is changing the air cleaner compulsory or I can go keep the stock air cleaner while just having the slip on?
This will be my 1st HD and some advise on this would help a lot.
Thanks
Thanks
o. well i'm not an expert. ive just noticed some say you will want to have a remap, and some say no you dont. what im doing:
- cheap K&N
- knocked out baffles (tonight i did . about the same as slipons)
- getting the XiED to help run proper air/fuel
I dont plan on taking it anywhere.
- cheap K&N
You can absolutely add the SE's without changing the AC or re-mapping. You will maintain the needed back pressure with no sweat. You will not, however, attain any increase in speed/power nor achieve any type of performance increase. You will simply be altering the sound of the exhaust note.
If you open the intake (AC change to free-flow type & re-map - i.e., intake part of Stage I) you would have to swap out the restrictive stock mufflers to allow the increased exhaust gases to flow with less restriction or risk devasting over heating and too much back pressure against the valves.
Just want a better sound? Go ahead and add the SE's with no other mods and you'll have no problems.
Better sound is only thing I am after as of now. Maybe a few months down the line, I'll change the Air Cleaner (SE Heavy Breather) and get a remap. Will I need to change the exhaust at that point if I have this Screamin Eagle slip-on installed?
Thanks so much for clarifying it.
If you're looking for better sound now, and a performance upgrade later on (Stage I), try to find a set of original SE II's or another set of free-flowing slip-ons that won't need to be swapped out when you open the intake.
It's the current situation that has had me worried though but I am resting easy after reading your last post.
Heres the deal. The SE slip on's suck, unless you want the bike just a bit louder then stock. You can run the slip on's and the stock AC with no issues at all. The 1200C i just got rid of had Rush slip on's and SE AC with not remap and the bike ran great, plugs did nto ever look bad whrn I pulled them.
