better ride
My wife rides and 883L and I just added Progressive 440's in 13.5". Wow. This bike rides great now. It previously had 11.5" 412's. The 440's allow a rebound adjustment along with spring tension. The taller shock as stated above allows more travel which si the main issue with the L version of the bike.
I'm going to add some Progressive stock length springs to the front and some Ricor Intiminators and I will riding on rails next. I gotta mke this bike handle well. The extra 2" in height is not an issue for me or my wife as we are both 5'10".
Drew
Drew
I need to change shocks on my 883r as well. Im about 225 and I had to stiffen the shocks up in the back to keep the bike from bottoming out, but now my back is just getting pounded. Ive been debating between the progressive 412/440's and the road king air shocks. For you guys that went the air shock route, are they a direct bolt on and how hard are they to set up and adjust?
The air shocks are pretty much a bolt on, you'll need some shock spacers, HD part # 6219 and longer bolts, top one is 1/2" UNC and lower one is 1/2" UNF, along with some 1/8NPT schrader valves to adjust the pressure.
There is loads of info on this conversion both here on this forum and on some of the others, as I said before best thing I've done to my bike without a doubt, even my wife said she's a lot more comfortable when we ride 2 up as I just add more air, simple!
I bought my 2007 883L used. It came with the sportster saddle bags. If I go with the air shocks, being that they are fatter than the stock shocks, will I still be able to use the saddle bags? They have a piece that wrap and snap around the back blinkers. Will the fatter shocks make them stick out too far to work?
jogg77
13
10-25-2010 09:10 AM
