Bike starting on its own
Old 07-12-2011 | 08:23 AM
cHarley's Avatar
cHarley
I would start by pulling the solenoid wire off of the starter and seeing if it still happens. If it does, the problem is in the starter assembly. If it doesn't, the problem is in the electrical wiring, switch, relay, etc.
Old 07-12-2011 | 08:59 AM
XL50#674's Avatar
XL50#674
If you replaced the relays then I would really check the start button-seems to be sending power at all times when the run/stop switch in on run.
Old 07-12-2011 | 09:12 AM
voddrummer's Avatar
voddrummer
5th Gear
Thank you all for your reply's! This is good stuff. I haven't been able to concentrate on anything other than getting this fixed lately, so I really appreciate all the comments and suggestions.
I will try these out tonight when I get home from work and will post an update as soon as I have one.
Thank you again.
Old 07-15-2011 | 08:53 AM
voddrummer's Avatar
voddrummer
5th Gear
update:
I decided to go to my local dealership and pickup a new starter switch assembly. This included the start button and run switch, $60. Installed the new switch and so far (keeping fingers crossed) everything is working like normal. So seems like there was a problem with the internals of my previous start switch. (i've been told Harley made a bad batch of these at one point and getting them wet only makes matters worse, i've also been told the new switches are a much better design).
Thanks to all for your replies and suggestions, you guys kick ***. Now 8 hours of work before I can go for a cruise...
Old 07-15-2011 | 09:52 AM
BreezyKollins's Avatar
BreezyKollins
Sick @$$ bike Vod!!
Old 07-15-2011 | 01:28 PM
voddrummer's Avatar
voddrummer
5th Gear
thanks man, appreciate it!
Old 07-16-2011 | 12:07 AM
Rudy12's Avatar
Rudy12
Originally Posted by BreezyKollins
Sick @$$ bike Vod!!
No kidding, would love to see more pics of it please.
Old 07-16-2011 | 12:43 AM
matt1080's Avatar
matt1080
Originally Posted by lgenf
Sounds like a short in the starter or starter switch
+1 I say disconnect the start switch first and turn it on if its not that its your selenoid
BigOrangeNightster
Electrical/Lighting/Alarm
20
04-22-2022 11:02 PM
sarpeezy
06-12-2015 06:16 PM
knights
06-26-2013 07:51 AM
scot210
06-25-2012 02:03 PM
Bearcat1
02-28-2010 12:36 AM
Quick Reply: Bike starting on its own
