PROs N Cons of replacing your own shocks
Here's the deal:
I have a '06 XL1200C Sportster. I Bought Progressive Shocks and had the dealer install them $48.00 O.K. Then I had the Dealer put my Stock Shocks back on, another $48.00; why - because I could not get my lift under the bike in order put it in storage. Now when return I want to run her with my Progressive shocks - that's right another I'm looking at another $48.00, when I leave again another $48.00...wow, get the picture.
Does anyone have experience in switching out their shocks?
How complicated is it to do the shocks myself?
What specialty tools would I need?
Should I do this with the bike raised on the stand?
How dangerous is it for me to do my own suspension work?
All advice welcome and very much needed. Thanks
RE: PROs N Cons of replacing your own shocks
The first time, I simply unbolted them, attached the lower mount, had the wife lift up on the rear fender a bit & slid the top bolt in.
The second time I had it on my lift and used a floor jack to lift the rear wheel in position.
Oh, and no CONS
Oh, and no CONS
Why do you need to switch out your shocks for storage?I park the bikes on a piece of plywood to eliminate contact with the floor.Did it for 4 years with my old bike without one problem.If you can't get the lift under the bike with the progressives on you won't be able to get the lift out from under it if you swap them either if you use the lift.
Thanks to all, I will DIY / DIM; To answer a couple questions
1 - Putting the progressives back on cause it looks better :>)
2 - I had to put the stocks back on when I put in in storage because there is no room in the closet (literally) to roll the bike up on 2x6s to get the lift under.
3 - Yes, when not in the closet and with the progressive shocks on, I have to roll the bike onto 2X6s to get the lift under if I am going to raise the bike.
Yes, it is a pain but worth it, more so now, since I can keep my $48.00 bucks for something else. Thanks again.
I am still kinda wondering about the torque for the bolts...would I need a torque wrench?
