Shifting without the clutch?
Old 06-21-2011 | 10:25 AM
FlatIron's Avatar
FlatIron
Default Shifting without the clutch?
I was just curious how bad it is to shift without the clutch when at WOT and banging gears. This is my 1st motorcycle, let alone my 1st Harley. I have been a car guy for a while and i am pretty sure motorcycles do not have syncros like car transmissions. Also cars have Helical cuts gears while motorcycles have straight cut gears,right?
I just ask because yesterday while getting onto the highway i was at WOT and shifted into 3rd without the clutch by mistake, i didn't even notice cause it felt the exact same as shifting with the clutch, i do not plan on doing it regularly, i was just curious if it would damage anything.
Thanks
Old 06-21-2011 | 10:41 AM
Guest
Guest
Posts: n/a
You shouldn't be able to shift without the clutch at WOT. You should have to unload the transmission by momentarily closing the throttle, then shifting.
However, if you do that, you will not harm the transmission at all. Any competent mechanic will tell you that correctly shifting without the clutch is the best way to shift for the longevity of the vehicle. Other than pulling away from a stop, I can't tell you the last time I used the clutch.
cacomly (12-18-2017)
Old 06-21-2011 | 10:48 AM
XL50#674's Avatar
XL50#674
When I had my dirt and sport bikes I would shift without the clutch at times, but I never do it on my sportys. Will it hurt them, maybe not, but how hard it is to pull the clutch lever in when shifting? not hard. This is a topic that will have split opions so do what you think is best.
Old 06-21-2011 | 10:49 AM
XTsHOG's Avatar
XTsHOG
There is a sweet spot which you will feel on the shifter when you shift as long as the rpms are high. Alot Of times I go into 3rd wo the clutch cuz my left boot is on my highway pegs and I use my heel to kick it up. Generally I don't power shift with other gears as the rpms have to b high and I don't think the hd gears would like it being abused. On my first metric bike Id popped the first gear and power shift right thru all power bands if I felt the need for speed. Grant it I'd b doing over 100 in very quick time. I wouldn't dream of doing thSt on my sporty. Lol
Old 06-21-2011 | 11:25 AM
bmxatv's Avatar
bmxatv
aw **** here we go again......lol.
Old 06-21-2011 | 11:36 AM
Guest
Guest
Posts: n/a
Pretty soon you'll get someone suggesting that there are already a dozen threads about this, and you should have done a search. Oh, crud, I guess I just did...
Old 06-21-2011 | 11:37 AM
xFreebirdx's Avatar
xFreebirdx
It is that time of the month again, isn't it?
Old 06-21-2011 | 11:48 AM
FlatIron's Avatar
FlatIron
im sorry i messed up in my description, yes i came off the throttle when shifting, figured that was a give in.
I did use the search but didn't find any threads that really answered my question. Sorry for being a pain in the *** Newb
Old 06-21-2011 | 11:51 AM
FlatIron's Avatar
FlatIron
Appreciate the input guys, you have pretty much answered my question.
Thanks
Old 06-21-2011 | 12:05 PM
Guest
Guest
Posts: n/a
No sweat, I just saw that coming. It was meant entirely tongue-in-cheek and/or self-deprecatingly, really. I forget that these things don't translate well to print/internet very well...
