Iron Headlight Options
This is something that I definitely considered installing on my Iron..gets ride of the headlight brow and lowers the speedo!
https://www.hdforums.com/forum/sport...o-and-w-w.html
two of my variations
2010 iron with stock light flipped and lowered to the lower tree.
you neeed to flip the glass portion upsidedown so your high/lowbeam is correct. the metal ring between the glass and housing needs to be flipped and turned around backwards. if done right you don't need to alter a thing permanently in the light. you need to fab a bracket to bolt to the tree for the light to bolt to. only have the one pic:
after changing the bars out i found the light too low. i moved it up above the factory position with this bracket i made from 3/16 sheet steel:
the wires will need extending to make it up, out this far and inverted.
a few poor cell pics of the new position:
