Primary Cover Oxidation?
Hey all,
I have a 93 1200 with the aluminum outer primary cover that has seen better days. It looks like it is oxidized/finish has whitish type spots on it...Has anyone ever seen anything like this? Any idea if i can clean it or do i have to replace the cover? If so, can i get another aluminum one somewhere? I don't think i wan to start to getting into the chrome because once you start, you always want a little more. Thanks for all of the help in advance...
Yes, I've seen it, and it's just oxidation/pitting. You can clean it up by sanding the whole cover down with fine sand paper and then buffing it with rouge & buffing wheel. What type of finish you want, (buffed aluminum or chrome), depends on you. If you progressively get to the real fine sandpaper and really buff the cover out, you can get it to basically look exactly like chrome.....Or just slightly sand it and then barely buff it out for the factory aluminum look.
When I did my fork lowers and headlight eyebrow, I did a combination of dry and then wet sanding. I think I ended with something like 1200 or 2000 grit wet sandpaper, and then buffed it out to look like chrome. Yes, you could use the Mother's aluminum polish and powerball. The polish and powerball really did wonders on my truck rims. Heck, you could just use some scotchbrite pads and then buff it out a little too.
