09' XR-1200 Low end bogg !
That's normal for such low rpms. The power band of these motors is in the 3000+ rpm range. Under 2000 rpm is what many call "lugging" the engine. It won't run real great and there is very little power. The XR is a little better tuned, but still, you gotta get up in the power band. You shouldn't ever be under 2000rpm except idle/taking off. In fact, you can actually do some damage if you are consistently putting a load on the engine under 2000 rpms outside of taking off from a stop.
Streetking66
General Topics/Tech Tips
07-21-2010 06:12 AM
