please advise...1200R test ride in few hours
it's an '06 1200R with 1,500 miles...if the weather permits i'll be test riding it in a few hours...i already saw it last weekend and seems in good condition, started right up yet decided not to ride it cause of extremely heavy rain...it's a private seller and second owner of the bike, he bought it with 300 miles...managed to lower the price to $5,400 which i consider a good deal...it comes with the stock seat, a well padded 2up seat, short sissy bar, forwards controls (which i'll change to mids or rears), v&h short shots...
please give me some advise on things to look for...so far i've only noticed that while in idle the motor shakes a lot, i've read this is normal for sportster, still would like to know how to check the motor mounts...
i'll be changing fluids cause the current owner never did...
thanks
thanks
Its carbed so lets hope he rejetted for the pipes..
Shake at Idle,,,normal.
Get er warmed up real good and ride the **** outta that Roadster.
It should pull hard all the way up the tach.
Should be no seal leaks with those low miles,,,If the rockers are leaking due to age,,
Buy It anyways,,no biggie.
A clunky tranny,,normal,,clutch should enguage mid pull,,you should have good friction zone control.
The bike should track well but If there is a little wobble at hi speed,,no worries
can be tuned out.
After Its fully hot check the Oil on the side stand.
Poor the power to It,,sportsters love to rev.
As soon as you roll out the vibes should be next to nothing,,unless your lugging It.
when yer swingin the tach It may start to vibrate around 4,000 rpm's and should
smooth back out around 4,400 rpms.
If It seems a little buzzy check the plugs.
Stock and or too lean they will be white and or chalky white.
Just right they should be a copper/coffie color.
If the bike feels solid and pull's hard like a freight train buy it.
check for signs of a drop tho.
2006 1200R,,after all that if the tires are good an It's a cream puff,,,$5,400
If It's anything less $5,000 or you walk away XD
FYI,,Carefull with those dual front brakes,,don't grab em cause they Is powerful.
Twice the swept area means half the hand pressure.
can be tuned out.
Besides,,whats a extra 500 or thou for a bad *** Roadster.
Your gonna blow that times two hangin bling on It anyways.
thanks osco...i've been wanting and watching for a sporty for a while, and this one seemed great...carbed, rubber mounted motor, black motor, dual front disk brakes, tach...
i'm in love with the 48 but dealer asks $13,200...
briefly test rode the roadster cause didn't feel safe on it, barely reached the shift lever, i think has extended forward controls, my legs where completely stretched and i'm short...
findings:
1. the front brack switch gets stuck and the lever rattles as if its the not correct part
2. the front motor mount is rusted
3. the threads for mid-mount foot controls are rusted
4. there's slight rust in the rear shocks, forks tubes and other places, not too bad
5. chome peeling on right side front peg
probably will need also need a new battery and the vehicle license expires this month, that's $175...
turns out the previous owner lived near the beach...
i'm put off buying this bike...
there's another '06 roadster listed for $7,900...way too much, and the tins are yellow so i would have to paint her...did the 1200R ever come stock with laced rims?
findings:
