Did I blow a fuse?
Did I blow a fuse?
I took of left rear s/s plate with side marker light off to connect a led third brake light I've been waiting for. Got everything connected and turned bike on. Speedo doesn't turn on nor does the oil and check engine light turn on. After about 5 to 10 seconds hazards flash a couple time and go back to running lights. Horn and turn signals do not work.
If i hit the rest button the speedo mileage will turn on but thats it. Bike WILL still start.
Anyone know
fyi I had the turn/brake/run conversion
Anyone know
ok so i blew one the fuses, replaced it and found out how i did it by blowing it again.
I got a led flex light from custom dynamics and wired in the Eclipze2® Module . When i turn the bike on led wont turn on for running lights and when you hit the brake it blows. The leds works as a single intensity. Do you think I have a bad Eclipze module?
Helyas
05-25-2009 09:44 AM
